Where can I download the help documentation for Hyperworks 2021?
User: "Bocaj22"
Altair Community Member
Updated by Bocaj22
Hello,
I can't find the documentation download on the Altair One apps page. I was able to download the documentation for the solvers, but not for Hyperworks Desktop applications like Hypermesh. Having the files locally is much faster than going through the internet for everything.
Thanks,
Jacob
1 - 8 of 81
    User: "Wesley Castro_21290"
    Altair Employee
    Updated by Wesley Castro_21290
    Hi Jacob,
    You can find the HyperMesh help documentation through Altair Marketplace. See screenshot below. Here is also a direct link for you: https://altairone.com/Marketplace?app=HyperMesh
    Thanks,
    Wesley
    User: "Bocaj22"
    OP
    Updated by Bocaj22
    Hi Wesley,
    Thanks for your response. Although this looks like it has all the same information (in a giant PDF), I'm looking for the HTML help package that can usually be installed alongside Hypermesh. It allows search, for example, and is usually accessed via "F1" or via the help toolbar in the application.
    Thanks,
    Jacob
    Altair Employee
    Hi Wesley,
    Thanks,
    Jacob
    Try this link instead: https://2021.help.altair.com/2021/hwdesktop/hm/index.htm
    For future reference the online help product documentation can be found within the "Knowledge Base" section of Altair One.
    Here is also a direct link for that: https://community.altair.com/community?id=kb_home
    Hope this helps!
    Thanks,
    Wesley
    User: "Bocaj22"
    OP
    Updated by Bocaj22
    Right, that is the documentation I am looking for, but I want it installed locally so I don't need to go through the internet to access it. In past versions of Hyperworks, that entire documentation would exist here essentially:
    C:\Program Files\Altair\2021\help
    Is that no longer possible, starting with 2021?
    Thanks,
    Jacob
    Altair Employee
    Accepted Answer
    If you do not see the help documentation there that is because it was not installed in the beginning. You will need to download the executable shown below.
    It can be found with this link (https://connect.altair.com/CP/dw-suite.html) after selecting "Simulation Products."
    User: "Bocaj22"
    OP
    Updated by Bocaj22
    Thanks, that's what I was looking for. I'm not sure why it would exist only on Altair Connect but not Altair One Marketplace. Perhaps that is a mistake. Only the Solver Help can be found on the Marketplace.
    Altair Employee
    I agree with you. This needs to be also available within Altair One Marketplace. Sorry for the confusion it caused.
    Kind Regards,
    Wesley
    User: "Bocaj22"
    OP
    Updated by Bocaj22
    No problem, I appreciate the help!
