Removing pinholes but leaving points
Rafał Szypulski_22596
Rafał Szypulski_22596 Altair Community Member
edited August 2022 in Community Q&A
Hello!
Is there any way for the pinhole's centerpoints to remain after their removal? I need them placed in a seperate component for further application of CFASTs. Thank you in advance.
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited July 2022
    Did you try activating display of the 'fixed points'? If I remember correctly, these central points are kept by default into the surface
  • Rafał Szypulski_22596
    edited July 2022
    Is there any other tab dedicated to fixed points to the one shown below? I've tried unmasking and showing everything but still can't seem to find the pinhole points. I remember back in HM 2020 that wasn't a problem - I've recently updated to HM 2022... maybe they changed thatfeature...
    edited July 2022
    Adding points manually displays them without any issues. Do you have another idea what may be the reason? Thank you very much!
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited August 2022
Welcome!
Welcome!
