Hello!Is there any way for the pinhole's centerpoints to remain after their removal? I need them placed in a seperate component for further application of CFASTs. Thank you in advance.
Did you try activating display of the 'fixed points'? If I remember correctly, these central points are kept by default into the surface
Is there any other tab dedicated to fixed points to the one shown below? I've tried unmasking and showing everything but still can't seem to find the pinhole points. I remember back in HM 2020 that wasn't a problem - I've recently updated to HM 2022... maybe they changed thatfeature...
Adding points manually displays them without any issues. Do you have another idea what may be the reason? Thank you very much!
