🎉Community Raffle - Win $25
Join and Win
Fatal Error
User: "Mohammad Bhatti"
New Altair Community Member
Updated by Mohammad Bhatti
I am receiving a fatal error when trying to set up some linear static analysis using optistruct profile. The error reads as seen below:
 *** FATAL ERROR # 9171 ***
 32-bit overflow in memory allocation for 'lgnnl'.
I am not sure how to solve this. Any help would be appreciated!
Best Wishes,
Mohammad Bhatti
1 - 1 of 11
    OP
    I would also like to add that the mesh has almost 50 million elements, could this be the cause of this error? Should I increase the element size to try and counteract this and maybe the error will be solved? Any thoughts?
