🎉Community Raffle - Win $25
Join and Win
Radar Cross Section (RCS) simulation of a triangular corner reflector
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi everyone,
i'm trying to simulate a pretty simple layout for verification reasons:
The layout consists of a triangular corner reflector with the length of the inner edge to the corner of 0.5m.
I'm calculating at 5.7GHz and search for the Radar Cross Section (RCS).
In order to calculate the RCS I've added a plane wave along the X-Axis and a Far Field Request with varying configurations (which all returned the same result).
The RCS seems to be (according to Feko) roughly 82m2, but the Formula i've been using has been giving me 94m2 which is closer to what we've measured (a bit more than 100m2 at boresight).
σ = 4·π·a4 where a = Length of the side edges of the three isosceles triangles
λ = wavelength of scanning Radar
(7)
3·λ2
(Source: http://www.radartutorial.eu/17.bauteile/bt47.en.html)
Am i making any fundamental mistakes in my calculations or simulations?
Greetings
Cupacoffee
1 - 5 of 51
    User: "JIF"
    Altair Employee
    Updated by JIF
    Hello Cupacoffee,
    Do you mind adding your model? I know it is easy for me to re-create, but if you add it, I don't have to. ;-)
    User: "Johan_Huysamen"
    Altair Employee
    Updated by Johan_Huysamen
    Hi Cupacoffee
    I believe that the corner reflector as described in your reference should have 90 degree internal angles. Your screen shot from CADFEKO does not appear to show 90 degree angles.
    You should check to ensure that this geometry is correct.
    Altair Employee
    OP
    Hello Cupacoffee,
    I've uploaded the model. Thanks for looking into the issue.
    Hi Cupacoffee
    As can be seen in the screenshot all inner angles appear to be 90°, you can verify with the model aswell.
    Greetings
    Cupacoffee
    Altair Employee
    OP
    I've figured out the source of the problem myself: The boresight of the Reflector was not aligned properly as can be seen in the screenshot.
    I had a ~ 10° offset which explains the low value. The new value of 102.5m nicely lines up with the measurements we conducted.
    Thanks to everyone who looked into the issue.
    User: "Eric Neumann"
    Altair Community Member
    Updated by Eric Neumann
    Hello Altair Forum User,
    can you tell me which value you changed to 102.5m to achieve the correct boresight? Did you rotate the whole thing?
    Thanks in advance :)
