🎉Community Raffle - Win $25
Join and Win
Batch Script Error
User: "bouvy"
Altair Community Member
Updated by bouvy
Hello,
I am trying to run a batch script from the FEKO terminal. When doing so, I get the following error, and my job does not run:
Error connecting to the Service
[mpiexec@vem-2] ..\hydra\utils\sock\sock.c (270): unable to connect from 'vem-2' to 'VEM-2' (No error)
Where 'vem-2' is the name of my PC.
I have attached text files of both the job script and the complete output from the FEKO terminal. Any help is appreciated!
Thanks,
Alex
1 - 4 of 41
    User: "Torben Voigt"
    Altair Employee
    Updated by Torben Voigt
    Hi @bouvy,
    Does running a simulation from CADFEKO work?
    User: "bouvy"
    OP
    Updated by bouvy
    Hi Torben,
    Yes, no issues running from CADFEKO.
    Thanks,
    Alex
    User: "JIF"
    Altair Employee
    Updated by JIF
    Hi bouvy,
    I assume that all 40 cores are on the same machine? If so, add the following to the end of the runfeko command:
    --parallel-authenticate localonly
    User: "bouvy"
    OP
    Updated by bouvy
    JIF, this seems to have done the trick.
    Thanks!
