Altair RISE
Nominate Yourself Now!
Set distance between two nodes
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all.
I need help on tcl hypermesh scripting. What command do you use to set a distance between 2 nodes. Manually i would press F4, select two nodes as if i'm measuring the distance and then just type in new distance value to my preferred distance. When i look into the command file, the command is *nodemodify, but the problem of this command is that it use the coordinate of the nodes rather than a specified distance value.
Thank u very much in advance.
1 - 3 of 31
    Altair Employee
    OP
    You can use the command
    hm_getdistance entity_type id1 id2 syst_id
    Altair Employee
    OP
    Hello,
    here is a simple example how to implement such a function.
    I have included the inputs, so you can check it.
    *createmarkpanel nodes 1 'Select first node';
    set node_list1 [hm_getmark nodes 1];
    if { ! [ Null node_list1 ] } {
    set nodeId1 [ lindex $node_list1 0 ]
    set x1 [ hm_getentityvalue nodes $nodeId1 'x' 0 ]
    set y1 [ hm_getentityvalue nodes $nodeId1 'y' 0 ]
    set z1 [ hm_getentityvalue nodes $nodeId1 'z' 0 ]
    *createmarkpanel nodes 2 'Select the second node';
    set node_list2 [hm_getmark nodes 2];
    if { ! [ Null node_list2 ] } {
    set nodeId2 [ lindex $node_list2 0 ]
    set x2 [ hm_getentityvalue nodes $nodeId2 'x' 0 ]
    set y2 [ hm_getentityvalue nodes $nodeId2 'y' 0 ]
    set z2 [ hm_getentityvalue nodes $nodeId2 'z' 0 ]
    *clearmark nodes 1;
    *clearmark nodes 2;
    set dx [expr $x2 - $x1]
    set dy [expr $y2 - $y1]
    set dz [expr $z2 - $z1]
    tk_messageBox -message 'Distance dx dy dz: $dx $dy $dz'
    set offsetx [hm_getfloat 'Offset X = 'Please specify the X - offset]
    set offsety [hm_getfloat 'Offset Y = 'Please specify the Y - offset]
    set offsetz [hm_getfloat 'Offset Z = 'Please specify the Z - offset]
    set nx [expr $x2 + $offsetx]
    set ny [expr $y2 + $offsety]
    set nz [expr $z2 + $offsetz]
    *nodemodify $nodeId2 $nx $ny $nz
    Regards,
    Mario
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi all
    I think SFUL wants to set the distance from node1 to node2
    I wrote this example, please test it
    ex: hm_setdistance 1 2 500.0 ==> when you F4 measuring distance from node id 1 to node id 2, it shows 500.0
    proc hm_setdistance {node1 node2 newdistance} {
    #get current distance
    foreach id {1 2} {
    set nodevalue [expr [hm_nodevalue [set node$id]]]
    set i -1
    foreach coord {x y z} {
    set $coord$id [lindex $nodevalue [incr i]]
    set currentdistance [expr sqrt(\
    ($x1-$x2)*($x1-$x2)+\
    ($y1-$y2)*($y1-$y2)+\
    ($z1-$z2)*($z1-$z2))]
    set deltadistance [expr $newdistance-$currentdistance]
    set temp [hm_getmark nodes 1]
    *createmark nodes 1 $node2
    *createvector 1 [expr $x2-$x1] [expr $y2-$y1] [expr $z2-$z1]
    *translatemark nodes 1 1 $deltadistance
    eval *createmark nodes 1 $temp
