Hi all.
I need help on tcl hypermesh scripting. What command do you use to set a distance between 2 nodes. Manually i would press F4, select two nodes as if i'm measuring the distance and then just type in new distance value to my preferred distance. When i look into the command file, the command is *nodemodify, but the problem of this command is that it use the coordinate of the nodes rather than a specified distance value.
Thank u very much in advance.
