🎉Community Raffle - Win $25
Join and Win
Inspire_Number of CPU cores?
AgustinUser: "Agustin"
Altair Community Member
Updated by Agustin
Hi I wanted to know how I should set up the Inspire run option in order to get full performance on the software
I have a Lenovo Legion Y540
processor: Intel Core i7-9750H CPU 2.6Ghz
RAM: 16Gb
Graphic Card: Nvidia GeForce RTX 2060
My main doubt is that the computer has 6 core processor but 12 logical processors
So I don't know if to put 6 or 12
Thanks
Agustin
1 - 3 of 31
    Hi Agustin ,
    You can go with 12 core Processor , you system configuration is sufficient to have a full performance on the software. Inspire uses maximum available cores from the machine,if it is in the default settings.
    Regards,
    Sourav
    OP
    Updated by Agustin
    Hi Sourav,
    Thanks for answering
    I found that inspire has the following options - > 6, 7, 8, 16
    So I should use the max without exceeding 12?
    Regards
    Agustin
    Hi Agustin,
    I would suggest you to use maximum for better performance :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
    Regards
    Sourav
