🎉Community Raffle - Win $25
Join and Win
How to mesh or cut surface by component name
ve3DUser: "ve3D"
Altair Community Member
Updated by ve3D
Hello,
I would like looking for the code to be able to mesh according to the name of the component. For example when I do automatic mesh for the component named 'NIV1_D0700', I got the code in the command.tcl file as below:
*startnotehistorystate {Automesh elements}
*setedgedensitylinkwithaspectratio -1
*elementorder 1
*setusefeatures 3
*createmark elements 1 1-56 3845-3910
*defaultremeshelems 1 0.4 4 4 1 1 1 1 0 0 0 0 2 30
*setusefeatures 0
*endnotehistorystate {Automesh elements}
It gives the ID numbers (red color) and not the name of the component, so I can not copy the code. I would like a line of code as below for example:
*createmark components 3 'NIV1_D0700'
In the same way, when I want to cut a surface by two points 'F11', Hypermesh generates a command with ID (red color) but not with component name. If I have a component with several elements (several id), Can I call only the component to make the cut. I asked the question because every time I corrected the geometric model in another software and import it again, the id of all elements are changed, the codes are no longer valid.
*createnode 20.5 30.15 -13.78 0 19 120268
*createnode 20.5 29.25 -13.78 0 19 66021
*mergehistorystate '' ''
*surfacesplitwithcoords 19 20.5 30.15 -13.78 20.5 29.25 -13.78
Someone can help me?
Thanks in advance,
Best regards,
1 - 10 of 101
    tinhUser: "tinh"
    Updated by tinh
    you can select elems 'by comp name'
    *createmark elems 1 'by comp name' NIV1_D0700
    ve3DUser: "ve3D"
    OP
    Updated by ve3D
    Thanks a lot @Tinh
    I arrived to mesh several surfaces by code:
    *elementorder 1
    *createmark surfaces 1 'by comp name' 'NIV1_D0700' 'NIV1_D1000' 'NIV1_D2000'
    *defaultremeshsurf 1 0.5 4 4 2 1 1 1 1 0 0 0 0
    But I did not arrive to cut a surface 'F11' by two points with the same principe :
    *createmark surfaces 1 'by comp name' 'NIV1_D2000'
    *surfacesplitwithcoords 1 20.5 30.15 -13.78 20.5 29.25 -13.78
    Do you know how to do it?
    tinhUser: "tinh"
    Updated by tinh
    input argument for *surfacesplit is surf ID but not mark 1
    just 1 surf can be splitted per step so you have to input surf ID (number 19 can be retrieved by:
    *createmark surfs 1 'by comp name' NIV1_D2000
    set surfID [lindex [hm_getmark surfs 1] 0]
    ve3DUser: "ve3D"
    OP
    Updated by ve3D
    Hi,
    I tried to do as your explanation, but it does not work. I received the message 'unable to split the surface'
    *createmark surfs 1 'by comp name' 'NIV1_D2000'
    *surfacesplitwithcoords surfID 20.5 30.15 -13.78 20.5 29.25 -13.78
    Can you try it with the attached file please?
    Thank you in advance
    tinhUser: "tinh"
    Updated by tinh
    Hi
    error is at this
    must be: surfacesplitwithcoords $surfID
    ve3DUser: "ve3D"
    OP
    Updated by ve3D
    HI @tinh
    It works, thanks very much for your help
    Best regard
    ve3DUser: "ve3D"
    OP
    Updated by ve3D
    Hi @tinh
    Does this method work when there are multiple surfaces in the same 'component' ?
    In fact,  I would like to do an automatic macro to cut the floor in several areas between two feet of the doors as the figure below. To do this manually, I have to use F11 and choose every couple of points for each foot of the doors. Hypermesh gives me commands and coordinates as below:
     *surfacesplitwithcoords 18 15.55 33.9 -13.78 15.55 33 -13.78
    *surfacesplitwithcoords 10 15.55 18.2 -13.78 15.55 17.3 -13.78
    *surfacesplitwithcoords 17 23.6 8.15 -13.78 25 8.15 -13.78
    I can paste these lines on the * .tcl file and run it. The problem is that when I modify some geometry in the * .igs files in the CAD software, the ID numbers of the surfaces (18, 10, 17) will be modified in Hypermesh. The macro does not work anymore.
    Your method allows giving the surface corresponding to the component 'NIV1_D2000'. But when the component 'NIV1_D2000' has several surfaces, how can we find the surface numbers (18, 10, 17) of the different areas of the component 'NIV1_D2000' to use the command *surfacesplitwithcoords ?
    You will find  in attached zip all the files concerning the inputs * igs (it is necessary to change the path) and the file * .tcl that I can not run using your method.
    It's too bad that the command * surfacesplitwithcoords is based only on surfaces and not on components
    Thank you very much,
    Best regard
    tinhUser: "tinh"
    Updated by tinh
    Yes it accepts surf id as input arg but not surf mark
    Given a coordinate, you can find the closest surf id by hm_measureshortestdistance2
    And then use that id for *surfacesplitwithcoords
    ve3DUser: "ve3D"
    OP
    Updated by ve3D
    Hi @tinh,
    I tried for example, but it is always 'Unable to split the surface':
    set surfID [lindex [hm_measureshortestdistance2 15.55 33.9 -13.78 surfaces 1 0 0] 5]
    *surfacesplitwithcoords $surfID 15.55 33.9 -13.78 15.55 33 -13.78
    According to the help, the return is a list of values: d dx dy dz id x y z
    So to take the 5th element (ID) in the output list, il tried:
    Is that correct ?
    Thanks
    ve3DUser: "ve3D"
    OP
    Updated by ve3D
    Hi @tinh
    I found the problem, in the list d dx dy dz id x y z, to have ID, we must take 4
    set surfID [lindex [hm_measureshortestdistance2 15.55 33.9 -13.78 surfaces 1 0 0] 4]
    So the first item is '0' as in python, and the 5th element is '4' ?
    d dx dy dz id x y z
    • d – The value of the shortest distance
    • dx – The x value of the shortest distance, measured relative to the specified local system
    • dy – The y value of the shortest distance, measured relative to the specified local system
    • dz – The z value of the shortest distance, measured relative to the specified local system
    • id1 – ID of the closest entity from the mark
    • x1 y1 z1 – Coordinates of the closest location on entity id1
