🎉Community Raffle - Win $25
Join and Win
Unable to specify force on the linear torque map powertrain system
I am creating a model of a two wheeler with a hub motor on the rear wheel. I wanted to include a simple powertrain system so I imported the linear torque map powertrain from the two wheeler model in the assembly wizard. I have not made any changes except add a force at the rear wheel center, on the wheel body.
I have specified the following expression under the Tz rotational properties of the force: `{sv_torque_output.VARVAL}`, the torque_output is a solver variable prespecified in the imported system.
I am running a straight line acceleration event with transient analysis with Motionsolve, with the Altair driver added.
I am getting the following error:
Can someone please help me solve this problem?
I have checked my model and there is nothing with the ID of 31800100, if that helps.
1 - 6 of 61
    PrafulUser: "Praful"
    Altair Employee
    Updated by Praful
    Hello Vedant
    Did you create the entire model using the Assembly wizard or did you just imported a system from the wizard library into your self created model ?
    Is it possible to share the model that you have ?
    regards
    Praful
    Altair
    Can you please try using Propulsion Torque once?
    Hello Vedant
    regards
    Praful
    Altair
    Hi praful,
    I can share the model with you if you can share your email ID.
    I have created the front and rear suspension system by myself from scratch. I have only imported the linear torque map powertrain by using this:
    I have exported the linear torque map powertrain from the wizard library.
    P.S: I narrowed down to the error in the model being in the powertrain system as the solver runs the npost shaker event without any errors.
    How I do define this solver variable? Which expression do I use?
    Altair Employee
    Updated by Praful
    Hello Vedant
    regards
    Praful
    Altair
    Hi Vedant - You may send the files to me - ppraf@altair.com.
    Regards
    praful
    Regards
    praful
    Hey Praful - I've sent you the archived model by email.
