Impactor does not perforate the laminate
Eli_B
Eli_B Altair Community Member
edited July 2021 in Community Q&A
Can someone help me to understand why the impactor bounces off the laminate instead of punching through it? In hyperview there is stress, but then it bounces.
What did I do wrong?
Thanks
Answers
  • Rogerio Nakano_21179
    Rogerio Nakano_21179 New Altair Community Member
    edited July 2021
    Hi
    In order to the perforation happens, you need to define the criterion for material failure.
    the /FAIL  does not have limit value , e.g., strain to the element deletion.
    the /MAT has the eps_max set, but maybe it is too large. eps_max is plastic strain, it is not the total
    I hope this is helpful.
    Regards
Welcome!
Welcome!
