Helo,
I am new to FEKO. I need help in designing printed circular coil. I want t o make 2 turn printed circular coil. How i can set spacing between teach turn. Also how i can select the particular material for designing coil.
Hi SQG
See here
Thank you very much but how can i set distance between 2 loops.
You adjust the variables created for the radii of the loops.
Hi SQG
See here
