🎉Community Raffle - Win $25
Join and Win
Discharge Trajectory Graph EDEM
User: "Pablo Reina"
Altair Community Member
Updated by Pablo Reina
Hello Everybody,
I want to know if in EDEM exists, any option available to graph the discharge trajectory of the bulk material simulated? I tried to find it in the Analyst section in the graph tab, but I could not.
Thank you for your responses
1 - 3 of 31
    User: "Stephen Cole"
    Altair Employee
    Updated by Stephen Cole
    Hi Pablo,
    In EDEM  you can use streamlines to visualise the trajectory :
    https://2022.help.altair.com/2022.2/EDEM/Analyst/AnalystTree-Display.htm
    Otherwise you could use selections to select a set of particles and export the X,Y,Z positions (over time if required or 1 time-step), its not something that is plotted by default but the data is there for the analysis.
    Regards
    Stephen
    User: "Pablo Reina"
    OP
    Hi Pablo,
    Regards
    Stephen
    Thank you Stephen for your response,
    How do I select a set of particles and export its position over time.
    Thank you for your time.
    Altair Employee
    Hi Pablo,
    You can use the Manual Selection function.  It's shown in the e-learning:
    https://learn.altair.com/enrol/index.php?id=147
    In the e-learning it's Lesson 17.6: Creating Selection Groups.
