Hello Everybody,
I want to know if in EDEM exists, any option available to graph the discharge trajectory of the bulk material simulated? I tried to find it in the Analyst section in the graph tab, but I could not.
Thank you for your responses
Hi Pablo,
In EDEM you can use streamlines to visualise the trajectory :
https://2022.help.altair.com/2022.2/EDEM/Analyst/AnalystTree-Display.htm
Otherwise you could use selections to select a set of particles and export the X,Y,Z positions (over time if required or 1 time-step), its not something that is plotted by default but the data is there for the analysis.Regards
Stephen
Hi Pablo, In EDEM you can use streamlines to visualise the trajectory : https://2022.help.altair.com/2022.2/EDEM/Analyst/AnalystTree-Display.htm Otherwise you could use selections to select a set of particles and export the X,Y,Z positions (over time if required or 1 time-step), its not something that is plotted by default but the data is there for the analysis.Regards Stephen
Thank you Stephen for your response,
How do I select a set of particles and export its position over time.
Thank you for your time.
Thank you Stephen for your response, How do I select a set of particles and export its position over time. Thank you for your time.
You can use the Manual Selection function. It's shown in the e-learning:
https://learn.altair.com/enrol/index.php?id=147
In the e-learning it's Lesson 17.6: Creating Selection Groups.
