I have run a freesize optimization but when i view the results i can only visulaize the element thickness and orientation thicknesses. Is it possible to also see the disp and stresses as well?
I can see disp and stresses only from analysis but not after when i run freesize optimization?
In the run folder run_name_s1.h3d (s1, s2... indicate the number of subcase) will have stress & displacement results.
Various results files are created during the optimization run- brief description can be found in:
https://altairuniversity.com/wp-content/uploads/2012/03/Bracket_OS_post.pdf
