🎉Community Raffle - Win $25
Join and Win
static crashing simulation set-up? (lsdyna)
Hi,
I want to do a crash simulation on a tube at the speed 1mm/s (static). Is lsdyna capable to do it? If yes, how should I set up the time step?
mesh size: 3mm
termination time: 600000ms
Many thanks.
1 - 2 of 21
    Hi,
    don't do it with LSDyna. It is a explicit solver for analyzing problems including high velocity, large deformation... using a explicit time integration.
    So LSDyna needs a small time step !!! There are a lot of informations at the internet...
    Regards,
    Mario
    tinhUser: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    mesh size: 3mm
    Many thanks.
    perhaps you should use *CONTROL_IMPLICIT, take a view on http://www.dynaexamples.com/implicit for setup guide
    first understand what IMPLICIT/EXPLICIT does and pay attention on contact issue
