🎉Community Raffle - Win $25
Join and Win
Optistruct - Force simulation
Dear All,
I am using Altair HyperWorks software to check and control the results of some new method, for structure borne noise characterisation, which I am investigating.
I am normally operating with mobilities (velocities) in particular nodes, while doing frequency response analysis (modal), but now I would need to simulate / measure forces in the nodes where spring attaches to my structures. (picture enclosed).
I have tried many different ways of gaining correct force information, but I was always unsuccessful.
I used GPFORCE output at freq. response analysis and than tried to plot total force, force in element, MPCForce, Applied force and everything else I found, but non of those options gave me the right result.
Could you give me some advice, how to “simulate” / “measure” the force on both sides of spring?
Because if spring is not massless force on one side will be different as force on the other side and I want to see the difference for various cases of my experiment.
Thank you very much for your help!
Best regards,
Luka Trampus
1 - 4 of 41
