Dear all
We know when make NLGEOM analysis, we should set DTI_UNITS cards. But there are not ISO ton unit in there.
when define the material, we asign E, NU, and RHO. If I use ton, N, and mm. The default DTI_UNITS are KG, N, mm and s.
how could I solve this conflict? Thanks!
You can set the unit system in Control Cards>>DTI_Units.
