🎉Community Raffle - Win $25
Join and Win
replacing the node
User: "Ushay"
Altair Community Member
Updated by Ushay
Hello all,
I am creating a beam element connected between two nodal rigid bodies with the line
*createspotweld $x $y 0 0 0 0 0 ''
Where x and y are the independent nodes of 1st and 2nd NRB respectively. When I look into file for generated beam element in the *ELEMENT_BEAM card (LS-Dyna), the 3rd node for the beam element is assigned with a random node id (but same coordinates as first node). Is there any possibility to replace the 3rd node id with the 1st node id?
1 - 2 of 21
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    Hello @Ushay
    I think you can create beam with '*barelementcreatewithoffsets' command.
    *createvector 1 1 0 0
    *barelementcreatewithoffsets Node1 Node2 1 Node3 1 0 0 '' 0 0 0 0 0 0 0 0
    Thanks,
    Imoto
    User: "Ushay"
    OP
    Updated by Ushay
    Hello @Ushay
    Thanks,
    Imoto
    Hello @Imoto,
    thanks for the reply.
    It is not accepting the Node 1 and Node 3 to be the same.
    I am trying to make the nodes 1 and 3 the same, to get something like this for a beam element.
    Thanks
