Is there a means for refreshing RapidMiners tables, without importing again?
1 - 1 of
11
There is a read csv or excel operator in rapidminer. This will get the updated file whenever you apply this as this points to the location where the files are saved rather than saving them in the repository.
please consider using data loading via an operator instead of import if this happens on a regular basis. The following video from RM Academy may be useful: https://academy.rapidminer.com/learn/video/data-loading-via-a-process
