🎉Community Raffle - Win $25
Join and Win
cant see fixed points
User: "Michael999"
Altair Community Member
Updated by Michael999
i cannot see the fixed points( as spheres) and i dont know why.
can someone help me.
 https://imgur.com/mkKwPiz
1 - 22 of 221
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    User: "Michael999"
    OP
    thats not working, i have tried to delete all the files then i even change the working directory, the funny thing is when i 2d automesh i see the nodes, but when i try to create temporary nodes, i just cant see them
    Which version of HyperMesh you are using?(Student Edition or Full Version/2017 0r 2019)
    Share screenshot of Help: Updates and System and Information
    Operating System?
    User: "Michael999"
    OP
    I tested this in EDU 2019 version and it works as expected.
    In the 2019 version we made changes in the graphic engine. Please test briefly if the environment variable HW_USE_OPENCL changes the behavior.
    Please do the following steps:
    1. Stop all instances of HyperWorks
    2. Set the environment variable to  HW_USE_OPENCL=0
    3. Start HyperWorks and check if the behavior has changed when clicking Grids.
    or
    Try updating graphic driver.
    User: "Michael999"
    OP
    excuse me for the ignorance, but where do i find this variable? i dont have it, and where do i change it?
    i updated my graphics card and nothing changed.
    UPDATE
    I dont believe it, but the problem got fixed, thanks!!!!!!
    after the new Environment variable.
    Thanks for the update.
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    UPDATE
    what to do in this?  i dont see 'HW_USE_OPENCL=0' option in this. please help
    User: "humblefool"
    Updated by humblefool
    It's not working..... please suggest something else.
    Altair Employee
    this procedure is not working....is there any other solutions
    Did you try with the environment variable suggested above?
    Altair Employee
    Teste isso na versão EDU 2019 e funciona conforme esperado.
    Na versão 2019, altere o mecanismo gráfico. Teste rapidamente se a variável de ambiente HW_USE_OPENCL altera o comportamento. Execute
    as seguintes etapas:
    1. Pare todas as instâncias do HyperWorks
    2. Defina uma variável de ambiente como   HW_USE_OPENCL = 0
    3. Registre o HyperWorks e verifique se o comportamento foi alterado ao clicar em Grids.
    ou
    Tente atualizar o driver gráfico.
    Como define essa variável?
    Altair Employee
    How do I access and change  'Set the environment variable to  HW_USE_OPENCL=0' ?
    Altair Employee
    Altair Employee
    I have the same Problem, but could not solve it by Setting this environment variable. Here is my System Information:
     System Information:
    Machine:                      amd64
    OS:                           windows Windows NT 6.2
    User:                         Julian
     Hardware:
    Processor:                    Intel(R) Core(TM) i7-4558U CPU @ 2.80GHz (4 CPUs), ~2.8GHz
    System Manufacturer:          Apple Inc.
    System Model:                 MacBookPro11,1
    Total Physical Memory:        8192MB RAM
     Operating System:
    Machine name:                 DESKTOP-QH8R045
    Operating System:             Windows 10 Pro 64-bit (10.0, Build 18362) (18362.19h1_release.190318-1202)
     Graphics/Display/OpenGL:
    Name:                         Intel(R) Iris(TM) Graphics 5100
    VideoProcessor:               Intel(R) Iris(TM) Graphics Family
    AdapterRAM:                   1 GB
    DriverVersion:                20.19.15.4835
    DriverDate:                   20171016000000.000000-000
    CurrentBitsPerPixel:          32
    VideoModeDescription:         2560 x 1600 x 4294967296 Farben
    User: "sgoggi@buffalo.edu"
    Updated by sgoggi@buffalo.edu
    UPDATE
    Can you tell me how to make the nodes visible in hypermesh. Though I created nodes I am not able to see it.
    What exactly should we change as environment variable .It asks for browse file .Is it the name of the variable or the path.what should be the path.
    User: "Navaneethakrishnan K"
    Updated by Navaneethakrishnan K
    Hi,
    I have updated the environment variables. Still It is not working could any one help me on this.
    I changed the graphic processor to run the software. It worked out for me.
    User: "shr3d3d"
    Updated by shr3d3d
    Same problem, can't see any nodes using student edition
    Altair Employee
    Creating a new system variable 'HW_USE_OPENCL' and setting its value to '0' has solved the issue for me.
    MacBook Pro with Intel Iris Pro 550 Graphics running latest Windows 10.
    Altair Employee
    User: "Felix Chen"
    Updated by Felix Chen
    or
    it works
