🎉Community Raffle - Win $25
Join and Win
How to fix the error after run into MSC Nastran software
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi guys,
I'm in the middle of completing my project. I'm using Hypermesh as my pre-processing for linear static analysis. However, when I ran the exported file into MSC Nastran, it turns out it comes out with bunch of list of error including the SOL, PARAM and etc. How do I fix it ?
Thank you in advanced.
1 - 5 of 51
    Altair Employee
    OP
    Hi @Muhammad Zulfakhri Adli
    Can you share the errors please?
    If the error is related to solver, kindly check with MSC support.
    Altair Employee
    OP
    As you can see, that is my injection moulding component. So, basically I would like to simulate the displacement of the mould plate when injection pressure is applied (Picture) I'm having trouble because the analysis result is zero.
    When I open HyperView to check for the results. The message log states that,
    1 Warning: GLSL program failed to link.  Some accelerated features may be
                  disabled.
       2 Message: The fragment shader uses varying gElemTexCoords_z2, but previous
                  shader does not write to it.
                  The fragment shader uses varying gAlpha_z2, but previous shader
       3 Warning: GLSL program failed to link.  Some accelerated features may be
                  disabled.
       4 Message: The fragment shader uses varying gElemTexCoords_z2, but previous
    Altair Employee
    OP
    Hi,
    What is the version of HyperWorks are you using, please share the updates you have on your machine and also share the details of graphics card details.
    Altair Employee
    OP
    Hi,
    I'm using HyperWorks v14.0.
    Altair Employee
    OP
    Hi,
    You can get the graphics card details by enter dxdiag in start > run and send us a snapshot of the display tab
    Here is a list of supported graphics card details for HyperWorks 14.0
