🎉Community Raffle - Win $25
Join and Win
How to get user input in HYPERVIEW
Hello
I want to take some values from user so how can I take values from user
Like in Hypermesh we use hm_getfloat
Is there any command which will serve same purpose in hyperview??
1 - 30 of 341
    tinhUser: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    please search for input box in tklib
    or you can write your own, by dumping tk_dialog, and add an entry on it
    Ok I will search for that
    But will direct tcl commands work in hyperview script?
    And it will be really helpful if you give any example script you have
    And will it pop up window or where we supposed to enter values?
    tinhUser: "tinh"
    Updated by tinh
    Hi
    i dont know direct command
    open window command and enter
    tk_dialog
    then enter
    dump tk_dialog
    it is a sample script
    found how to take input its easy
    puts 'Enter your name: '
    #flush stdout
    set name [gets stdin]
    #flush stdout
    set name2 [gets stdin]
    set sum $name
    set sum2 $name2
    puts 'Hello $sum'
    puts 'Hello $sum2'
    tinhUser: "tinh"
    Updated by tinh
    yes, it's easy
    if you need input by GUI, view tk_dialog
    Code for importing geometry in HM is as follows:
    *geomimport 'auto_detect' 'Z:/Users/CAD.stp' 'CleanupTol=-0.01' 'DoNotMergeEdges=off' 'ImportBlanked=off' 'ScaleFactor=1.0'
    How can I get these inputs like CAD location, tolerance, scalefactor from user when I run TCL script ?
    llyle_20499User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi Pritish,
    It will be idea for you to create GUI using TK. You can refer to HW GUI Toolkit
    1.    From the Start menu, select All Programs.
    2.    Select Altair HyperWorks.
    3.    Select Tools.
    4.    Select HW GUI Toolkit.
    You can also refer to the userguide to get started:
    https://connect.altair.com/CP/kb-view.html?jf=112968&f=&kb=112938
    tinhUser: "tinh"
    Updated by tinh
    set filepath [tk_getOpenFile]
    set tolerance [hm_getfloat tolerance input]
    set scalefactor [hm_getfloat scalefactor input]
    *geomimport 'auto_detect' '$filepath' 'CleanupTol=$tolerance' 'DoNotMergeEdges=off' 'ImportBlanked=off' 'ScaleFactor=$scalefactor'
    Hello Guys,
    Hope you are all doing well ! Your tutoring has helped me a lot in my initial coding.
    Now, I am looking to load a tpl file, but before loading I want to take user input for one variable (say span) and use that variable value in formules mentioned in tpl script.
    For that I am thinking to have a window pop up before running tpl file, which will store user input value(span) in one variable ($input)  and then using this $input in further tpl script.
    I was able to write this code for poping up window in hypermesh, but this is not working in hyperview when I call same tcl script.
    set input [hwtk::inputdialog -text 'Enter Span Value' -inputtype str \
        -x [winfo rootx $w] -y [winfo rooty $w]]
    tk_messageBox -title 'hwtk::inputdialog' -message 'Span: $input mm'
    1. CAN you guys help me to pop up a window in Hyperview which will store data in a variable ?
    2. How to integrate Tpl script in Tcl to achieve my objective ? or any other way to load the tpl file with Step 1 input in it ?
    Awaiting your replies !
    tinhUser: "tinh"
    Updated by tinh
    Please show what the error raised?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.02b6b89fa6c8d84bbc6bc336c81c3992.png
    tinhUser: "tinh"
    Updated by tinh
    Please replace '$w' by '.'
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.53069a2e34b27095467f64619cb45af9.png
    tinhUser: "tinh"
    Updated by tinh
    Tpl does not share variables with tcl
    Suppose sample.tpl is your file
    Add these tcl codes to dip $input in sample.tpl
    set fpt [open sample.tpl]
    set buf [read $fpt]
    close $fpt
    set buf [string map '\$input \'$input\'' $buf]
    set fpt [open sample2.tpl w]
    puts $fpt $buf
    close $fpt
    Now open the sample2.tpl
    sample.tpl is reserved
    HI,
    I am trying to get data from hyperbeam Eg. IY,IZ of a solid section. Can you please help me with script or command?
    Hi
    tk_dialog
    then enter
    dump tk_dialog
    HI,
    tinhUser: "tinh"
    Updated by tinh
    I searched its datanames but it does not have IY IZ,
    Maybe, you have to create a surface fits with that section , mesh it and use hm_getmoi
    Hi tinh,
    Can you please elaborate the meaning of surface fits?
    tinhUser: "tinh"
    Updated by tinh
    I mean a surface that fits with the section. Sorry for my english
    Hi tinh,
    My hypermesh model contains some Hyperbeam sections. Each section will have associated data like shown below,
    Area  =    777.34677330
    Centroid :
      Local
        Yc  =    0.00369492
        Zc  =    0.00048295
    Moments Of Inertia :
      Local
        IY  =    8385.75207149
        IZ  =    292739.17537076
        IYZ  =    0.00138714
      Centroidal
        Iy  =    8385.75189018
        Iz  =    292739.16475806
        Iyz  =    0.00000000
      Principal
        Iv  =    8385.75189018
        Iw  =    292739.16475806
        Angle  =    0.00000000
    How can i get this data to text or any readable file by using command because my model has many such beams and I need to extract this details of all the beams.
    tinhUser: "tinh"
    Updated by tinh
    I am searching...
    Plz wait
    tinhUser: "tinh"
    Updated by tinh
    I found command 'hb_getresults'
    But you have to pre-select a section
    Hi tinh,
    unfortunately its showing hb_getresults as invalid.
    tinhUser: "tinh"
    Updated by tinh
    You have to enter hyperbeam GUI first-_-/emoticons/default_sleep.png' srcset='/emoticons/sleep@2x.png 2x' title='-_-' width='20' />
    yes tinh, its working now.. thanks a lot...
    I would like to know that is there any command to switche to thyperbeam GUI.
    If it works then it would be very easy to get the required data.
    I am trying with  *createmark beamsects 1 'solid_section.0' ,
    but its not working..hb_getresults will only work if we switch to hyperbeam gui and select the particular beam section and switch back to model gui...
    tinhUser: "tinh"
    Updated by tinh
    Hi
    Try hm_launchhb
    Hi Tinh,
    Thanks for everything its working successfully....
    Just had one doubt.. Do we have any command to get back to hypermesh gui..(unlaunch hyperbeam)
    tinhUser: "tinh"
    Updated by tinh
    Sure, we have.
    ::HB_Framework::exit -1
    Yes its working successfully..thanks for your help Tinh..
    brahmadevUser: "brahmadev"
    Updated by brahmadev
    Sure, we have.
    Hello Tinh,
    where did you find this command ?
    I have searched it in the reference manual but couldn't find it.
    Also, is there a way to directly export all the available shell section data as CSV format through the TCL script?
    thanks and regards,
    Brahmadev.
1 - 30 of 341
