displacement is known loading condition that causes that displacement is required
CASE #2 – Straight Removal Load
Opposite of Case 1 – pull leafscreen straight out of slot until barb of clip passes through the slot – need to know max load to remove for all iterations.
Questions:
1. Should I consider nonlinear static analysis or nonlinear quasi static analysis to solve this problem? (I have assumed that the clip travels with velocity of 1mm/s in direction of displacement) is it necessary to make this assumption or I can forget about the velocity and do a nonlinear static analysis?
2. Which solver should I use? Optistruct or Raidioss?
3. Would you pleas guide me regarding the cases in which displacements are known and loading condition is asked like this problem. I would appreciate if you can send me any example or tutorial in this regard.
Hi Bita,
Since you know the amount that clip displaces, my approach would be to give an enforced displacement and this is equal to the known displacement and request for the SPC forces to know the force values required.
You can use OptiSrtuct solver for this.
