1 - 5 of
51
Hi /profile/93011-lfss/?do=hovercard' data-mentionid='93011' href='<___base_url___>/profile/93011-lfss/' rel=''>@LFSS,
Thanks for the info. That means, the unit will be in meter/mm/etc(distance) right? thanks for the helps.
Most FEA solvers are unitless, therefore it is the user's responsibility to follow a consistent set of units:
The DOFs 1-3 are displacements and the DOFs 3-6 are rotations (units are radians).
The textbox near the DOFs are used to apply enforced displacemente values, used in Non-Linear Analysis.
Check out this video where the user sets up an Enforced Displacement:
Also, for further clarification, you could refer to the panel help, by clicking F1 when the Constraints panel is selected. Here's the link to that page: https://2020.help.altair.com/2020/hwdesktop/hwx/topics/panels/help043.htm
Hope it helped!
