Hello,
I have corroborated that Von Mises STRESS is output considering this formula, with principal stresses
What formula does hypermesh uses for strain?
Thank you!
Hello, I have corroborated that Von Mises STRESS is output considering this formula, with principal stresses <?xml version="1.0" encoding="UTF-8"?> What formula does hypermesh uses for strain? Thank you!
Hi,
Normally, we use the same criteria for each solver ... Just be sure that you plot stress in Gauss point or ...
Cheers,
Hello Farouk,
WHat do you mean by same critera?
Hello Farouk, WHat do you mean by same critera?
I hope it will be clear for you
This was what I was searching for!
Thank you Farouk! /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
This was what I was searching for! Thank you Farouk! /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Welcome mate /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Hi,
Cheers,
