How to apply a variable direction pressure
User: "Ing_Gant"
Altair Community Member
Updated by Ing_Gant
Hello everyone, I'm using Hypermesh 2017 and I have a project where simulate the load of a belt on a pulley alog a wrap angle opf 111°, the pulley has trapezoidal groove(polyV type with 40°angle. In this simulation i made a semplified model that is a simple disk with a single trapezoidal groove.
For my analysis I have to apply two loads:
-a normal pressure wich vary along the arc of load: I succed to do with equa
The pressure should vary along an arc of contact of 111° with equation 76484*exp(y*0.32838), selecting the local coordinate cilindrical system, I give the two side of the trapezoidal grive as faces (I selected only that of the arc)
The tangential load along the arc of contact: I 'd like to do in the same manner but I cannot give a tangential direction along the arc of contact.
The only option for the direction is x-axis, y-axis, z-axis, vector and N1 N2 N3.
I tried all the possibilty:The y-direction is relative to the global system and there is not possibilty to specify that is relative to the local cylindircal system (it seems that the system is only relative to the equation), with the vector i can specfy a tangentail vecotr (that I make aside) but the dircetion don't vary.
There is a solution to make this?
I also try with the force laod and this works but the problem is tahta I wnat a pressure and not a force otherwise I have to calculate How many nodes/mm2 there are to make the calculation of the right force load to give
Normal Pressure load (succeded)
Tangential load (not succede): this are the option for the direction
This is the load that I give but is a force load applied to the nodes (also if I select the faces in the same manner) in this case the direction is relative to the local system (cylindrical sistem selceted), why this doesn't work for the pressure?
imageMaybe this is solved in successive version of the program?
Thank you for the help
1 - 2 of 21
    User: "tinh"
    Accepted Answer
    Updated by tinh
    Hi,
    Did you switch "magnitude=" to "equation="?
    You should use HM2019 because in HM2017 there is bug when creating pressures by this way.
    And are you sure solver will not zero this pressure when project p vectors to elem's normals?
    On HM2019:
    User: "Ing_Gant"
    OP
    Updated by Ing_Gant
    Hi tinh, yeah as you can see in the below printscreen, I set the local cylindrical csys but the progress along the arc is right but the direction is the y-axis opf the glibal system instead of that of the local.
    I tried also to assign the nodes relative to the face of the trapezoidal side to the local csys and then put the pressure load in order to see if in this way the direction set to the local y-axis but this doesn't works. However I don't know if I puit right the assign command to the nodes because I never do that operation of assignment (I do it going to menù>>Geometry>>Assign>>Node Refernce System and the n selecting the nodes and then selecting the systema poiunting the local csys)
    Anyway if is a bug of Hypermesh2017 I'll download and install the 2019 version.
    Thx
