Note Formatting For String Variables
I'm trying to find a way to include the result file name in my plot window without showing the full path. When I first create the .MVW file it looks fine, but when I save it and later reload the note shows the full path, which is typically very long and gets truncated.
I'm using the default:
'Result : {window.resultfilename} '
Which originally prints out something like this:
'Result: BracketModification1.odb'
But after a save and reload ends up looking like this:
Result: /mnt/home/bspeirs/projects/SomeProject/FEA/Install...'
Is there anyway to eliminate the full path? I just want the file name printed.
Or is there a way to have it truncate the leading portion of the path and keep the most relevant part?
Like this
'Result: ...omeProject/FEA/Installation/BracketModification1.odb'
Thanks.
This line of templex might do the trick (assuming that the actual file name is shorter than 100 characters):
{mid({window.resultfilename},strrchr({window.resultfilename},'/')+1,100)}
Regards
