Altair RISE
Nominate Yourself Now!
IGES - Surfaces from Hypermesh to ANSYS Workbench
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I have a complex geometry that I cleaned on Hypermesh: I have Suppressed edges and no more Free and Non-manifold edges, but Shared edges to define several surfaces.
I exported those 6 new surfaces into an IGES file in order to import them in ANSYS Workbench 15 for meshing and further analysis.
The problem is, once the file is imported in Workbench, I have almost 600 different bodies and visually only a line (which reveals to be a plane surface when I zoom-in a lot...), in other words, I do not recognize my geometry and this is obviously exploitable.
I think my Suppressed edges may alter something ...
Thank you in advance for your advices.
1 - 6 of 61
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    Have you tried changing the various options while exporting (you have a choice called export options), formats other than iges?
    so this problem does not occur if you export without suppressing the edges?
    Altair Employee
    OP
    Rahul Ponginan, thank you for your reply.
    Yes, I already tried to change the Export Options (Planes, Outer loop, Layers), in vain.
    Other formats ? Not really, as I have only IGES choice in Export Geometry. Maybe is there a way to generate a STEP file ?
    I tried to export without any Suppressed Edges, in other words, only Shared Edges (but as a consequence I have many surface whereas I wanted just my 6 new ones).
    Anyway, this option did not change anything.
    Altair Employee
    OP
    @PL_Hyper: Try STEP! For my experience, if STEP is available, always use this format. That's better than IGES.
    Altair Employee
    OP
    I would like to try a STEP, but how can I generate this type of file with Hypermesh ?
    In Export options there is only a choice for IGES.
    Thanks for your advice Q.NEGUYEN-DAI.
    Altair Employee
    OP
    Hi PL_Hyper,
    what is the version of HyperWorks are you using?
    is it a complete suite or student Edition?
    Altair Employee
    OP
    After all, I managed to avoid this problem and had a different procedure.
    I generated a mesh on Hypermesh and exported it into an ANSYS format.
    After what, I imported this file in Workbench and generated a Parasolid from the mesh in order to obtain my geometry (one body).
    In any case, thank you everyone for your precious help and advices !
    But, I would still have one little question: is it possible to remove definitively a Suppressed Edge (blue one) permanently from an HM model ?
