How to assign 1 property per 1 element in Hypermesh?
Hello all.
I have a model with properties assigned to groups of elements: 1 property per several elements.
Is it possible to split these properties as follows:
1 element - 1 property.
Element ID = property ID.
I suppose it can be done using some scripts.
Or even the way using Excel import \ export will be helpful.
