How to assign 1 property per 1 element in Hypermesh?
Hello all.
I have a model with properties assigned to groups of elements: 1 property per several elements.
Is it possible to split these properties as follows:
1 element - 1 property.
Element ID = property ID.
I suppose it can be done using some scripts.
Or even the way using Excel import \ export will be helpful.
it would be possible to create a script, for that, but maybe excel or some text editor would be enough depending on what you already have.
I'm attaching a similar script, not completed, that does something similar to your request, if I remeber correclty..
Try this code:
foreach eid $elemList { #creat property with pid=eid *setvalue elems id=$eid propertyid=$pid }
How to assign 100 prop to 8000 elems? Based on some criteria ?
Thank you.
Now I can split all properties in a way that each element has its own property.
So I have like 10000 properties. This is what I need.
But I still don't know how to assign to each property ID of an element inside this property.
Now I have Prop ID = 1 with Element ID = 2000 in it.
My goal to have Prop ID = 2000 with element ID = 2000.
If you want to assign property ID=2000 to element ID=2000 AND if all properties exist already, use my following code:
*createmarkpanel elements 1 'Select elements' set elemList [hm_getmark elements 1] foreach eid $elemList { *createmark props 1 $eid set propList [hm_getmark props 1] if { [llength $propList] == 1 } { *setvalue elems id=$eid propertyid=$eid } else { puts 'Prop ID=$eid does not exist!' } }
You can use 'Tool' => Renumber => Property,
but this automatical method is dangereous and you can get wrong results with element.
What's the difference between Prop 1 & Prop 2, shell thickness? Your elements are shell type?
I have 3 elm types.
Crod/Cbar and Cshell.
I did try Renumber tool, but in my case it's too time consuming to renumber properties 1 by 1.
As I can see the process:
1) choose element
2) check the property assigned to this element
3) now we have element ID and property ID.
4) set property ID = element ID - where I stuck.
But, as I understand there are 2 ID types in HM: solver ID and HM internal ID.
I tried *renumbersolverid properties 1 $elem_id 1 0 0 0 0 0 as it in command.tcl, but it doesn't work properly.
It's not a good idea to work on numbering (ID) of element/prop.
You have to found another method: element type, thickness, location,... maybe in combining with element sets,...etc.
Ok. Thank you for the help.
I did what I want.
My script is attached.
1) choose element
2) store elem ID and prop ID
3) create new property with PID = EID and Pname = EID
4) update new property with stored data from old prop
5) assign new property to element
You can do this using the Aerospace Tool. First you need to activate the tool by going to Preferences-User Profiles, on the box, select Aerospace Tool, then OK. The tool will now appear on the top bar.
Next select Aerospace-Spatial ID manager-Property by Element ID
Select the elements or all elements and proceed. A bit late but hope it 's useful
How many elements do you have in your model?
