🎉Community Raffle - Win $25
Join and Win
How to assign 1 property per 1 element in Hypermesh?
NikUser: "Nik"
Altair Community Member
Updated by Nik
Hello all.
I have a model with properties assigned to groups of elements: 1 property per several elements.
Is it possible to split these properties as follows:
1 element - 1 property.
Element ID = property ID.
I suppose it can be done using some scripts.
Or even the way using Excel import \ export will be helpful.
1 - 14 of 141
    QuyNguyenDaiUser: "QuyNguyenDai"
    Updated by QuyNguyenDai
    How many elements do you have in your model?
    it would be possible to create a script, for that, but maybe excel or some text editor would be enough depending on what you already have.
    I'm attaching a similar script, not completed, that does something similar to your request, if I remeber correclty..
    Try this code:
     foreach eid $elemList { 	#creat property with pid=eid 	*setvalue elems id=$eid propertyid=$pid }
    NikUser: "Nik"
    OP
    Updated by Nik
    ~8000 elements and ~100 properties
    How to assign 100 prop to 8000 elems? Based on some criteria ?
    NikUser: "Nik"
    OP
    Updated by Nik
    Thank you.
    Now I can split all properties in a way that each element has its own property.
    So I have like 10000 properties. This is what I need.
    But I still don't know how to assign to each property ID of an element inside this property.
    Now I have Prop ID = 1 with Element ID = 2000 in it.
    My goal to have Prop ID = 2000 with element ID = 2000.
    If you want to assign property ID=2000 to element ID=2000 AND if all properties exist already, use my following code:
     *createmarkpanel elements 1 'Select elements' set elemList [hm_getmark elements 1]  foreach eid $elemList {     *createmark props 1 $eid     set propList [hm_getmark props 1]     if { [llength $propList] == 1 } { 	   *setvalue elems id=$eid propertyid=$eid     } else {        puts 'Prop ID=$eid does not exist!'     } }
    NikUser: "Nik"
    OP
    Updated by Nik
    It's almost what I need, but I have 2000 elements in ID range 10000 - 12000 (example) AND 2000 properties with ID range 1 - 1999.
    Element #10000 has property with ID = 23.
    Goal is to renumber current element property with ID of the element.
    You can use 'Tool' => Renumber => Property,
    but this automatical method is dangereous and you can get wrong results with element.
    What's the difference between Prop 1 & Prop 2, shell thickness? Your elements are shell type?
    NikUser: "Nik"
    OP
    Updated by Nik
    I have 3 elm types.
    Crod/Cbar and Cshell.
    I did try Renumber tool, but in my case it's too time consuming to renumber properties 1 by 1.
    As I can see the process:
    1) choose element
    2) check the property assigned to this element
    3) now we have element ID and property ID.
    4) set property ID = element ID - where I stuck.
    But, as I understand there are 2 ID types in HM: solver ID and HM internal ID.
    I tried *renumbersolverid properties 1 $elem_id 1 0 0 0 0 0 as it in command.tcl, but it doesn't work properly.
    It's not a good idea to work on numbering (ID) of element/prop.
    You have to found another method: element type, thickness, location,... maybe in combining with element sets,...etc.
    tinhUser: "tinh"
    Updated by tinh
    In nastran, PID is equal EID by default if you don't assign property to element
    Don't use *commands in long 'for' loops, use 'puts' to write property cards to a file then import that file, it just takes a few seconds.
    NikUser: "Nik"
    OP
    Updated by Nik
    Ok. Thank you for the help.
    I did what I want.
    My script is attached.
    1) choose element
    2) store elem ID and prop ID
    3) create new property with PID = EID and Pname = EID
    4) update new property with stored data from old prop
    5) assign new property to element
    RR FlightStuctUser: "RR FlightStuct"
    New Altair Community Member
    Updated by RR FlightStuct
    You can do this using the Aerospace Tool. First you need to activate the tool by going to Preferences-User Profiles, on the box, select Aerospace Tool, then OK. The tool will now appear on the top bar.
    Next select Aerospace-Spatial ID manager-Property by Element ID
    Select the elements or all elements and proceed. A bit late but hope it 's useful
