🎉Community Raffle - Win $25
Join and Win
Using TWAPI for Writing Data to Excel
Girish2121User: "Girish2121"
Altair Community Member
Updated by Girish2121
Hi all,
I am looking out for any examples to write stress/node id data to excel sheet TWAPI in Tcl/Tk.
Thanks in advance,
Regrads,
Girish C Hirekerur
1 - 4 of 41
    tinhUser: "tinh"
    Updated by tinh
    Hi,
    If you just want to write raw data, write it as CSV text format (can be opened by excel)
    example
    set fpt [open example.csv w]
    puts $fpt 'NodeID,StressValue'
    puts $fpt [join 1 100]
    puts $fpt [join 2 200]
    puts $fpt [join 3 300]
    close $fpt
    ==> open example.csv by excel to see
    OP
    Hi Tinh,
    I need to write the data from Hyperview in an organised readable manner.I referred to an example as given below :
      package require twapi
      set excel [::twapi::comobj Excel.Application]
      $excel DisplayAlerts [expr 0]
      set workbooks [$excel Workbooks]
      $workbooks Open 'C:/Users/willblatt/BlattBros/Projects/10000 Temp/XLS_Files_Chip/CHIP_ASSAY_TABLE.xlsx'
      set workbook [$workbooks Item 1]
      set sheets [$workbook Sheets]
      set sheet [$sheets Item 1]
      set cells [$sheet range a1 c3]
      puts [$cells Value]
      $cells -destroy
      $sheet -destroy
      $sheets -destroy
      $workbook -destroy
      $workbooks -destroy
      $excel Quit
    $excel -destroy
    I tried to use the above example.
    i.How should I add New Sheet to the file.
    ii.Can change the name of the file from Sheet1,Sheet2,etc. to something different say :Normal Force,Axial Force.etc
    iii. Any detailed documentation of all the classes available in TWAPI ?
    Thanks in advance,
    Girish
    tinhUser: "tinh"
    Updated by tinh
    Hi,
    there is document of using twapi. you can search it on google
    for excel COM, perhaps you should look at MSDN
    https://msdn.microsoft.com/en-us/library/office/ff193217.aspx
    Why need XLS when you can make CSV?
