Discrepancy in far field calculation using specified labels versus all sources
Hello everyone,
I'm currently working on a project where I'm calculating far field results based on sources from elements with specified labels. This setting is configured in the far field settings under the scope tab. However, I've observed that the total of these field calculations does not correspond when I include all sources. For instance, I have divided a rectangular sheet into upper and lower sections. The combined far field values from these two segments do not align with the far field values calculated using all sources. I have attached a model example for reference.
Could someone please explain why there might be a discrepancy between these two results? I would appreciate any insights or suggestions on how to reconcile this difference.
Thank you!
Ji Joe,
You can add the complex E-field, see POSTFEKO.pfs which then should agree quite well. And maybe it would be better to use a finite groundplane to exclude the contribution of the infinite PEC. Note, your mesh is quite coarse.
In the attached zip you can see what I mean.
Best regards,
Torben
Ji Joe,
Best regards,
Torben
