Warnings while importing the files
Answers
Hi,
The reason for the warning message is, those case control cards are not supported in HyperMesh-nastran template and will be written under the UNSUPPORTED CONTROL CARD found in Analysis> control card panel. You can edit this control card and when you export the file, those changes will be considered.
You can also try updating to the latest HyperWorks version, HyperWorks 2017, where these may be supported.
0 -
Hello @George P Johnson,
thank you for your reply, if you allow me to know how i can modify these unread cards for corrected errors.
thank you in advance.
0 -
Hello
if i want to use functions of hypermesh in a script made by myself (example: apply the function: import solver deck) which allows me to display the window to choose the command file then import it.
if anyone can help me I would be very grateful.
thank you in advance.0 -
you can skip the link please
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
0
