Driver Resulting in Solver Failure
Hello,
Earlier I posted a question about the solver failing due to custom inertia values. Now that thing is sorted out, but the new thing is I am modeling with a detailed rider now, the solver is failing and sometimes not solving at all without error, so when I deactivate the driver, the solver works fine and when I activate it gives an error. I tried to simplify my model by adding a simple rider instead of the detailed one, but the error is still there. the error I get is the menitoned below. I have not edited the driver and have taken the default values for mass and inertia.
WARNING: Akima-interpolation -> Data out of bounds Spline id:0
Future messages for Spline will be suppressed.
Time=1.202E+00; Order=2; H=5.000E-04 [Max Phi=3.336E-07]
WARNING: [DASPK] The nonlinear system solver in the time integration could not converge
WARNING: EvaluateResidual failed (NaN encountered)! Future warnings will be suppressed.
Residual idx=2214, GS/310001 X1
ERROR: [DASPK] IRES = -2 was encountered and control is being returned to the calling program
DAE SOLVER STATISTICS (DASPK-Index3)
Number of solution steps = 1341
Number of residue evaluations = 445
Number of jacobian computations = 516
Number of error test failures = 4
Number of nonlinear convergence failures = 31
WARNING: Repeated abnormal return from integrator!
ERROR: At time=1.254E+00 the integrator failed to proceed.
after this there is list of probable causes.
Regards
Draucis
Hello Jagadeesh,
I have reviewed my model again with the points you mentioned, in the inertia values there are some components that contains inertia values larger than other components. As I don't have value for those components, I left it as default and I have done the PID tuning but that is not changing anything. I am attaching my model file here for your review.
Thanks a ton
Draucis
hi Draucis,
The modified model is attached here.
The issue was not with inertia values. The powertrain solver variables and rear monoshock suspension properties needed changes to run events
1] Edited FMU vehicle speed and throttle inputs. Vehicle velocity needed in FMU control should be in m/s. throttle value is in %.
2] Propulsion torque which is coming form FMU need to be changed to model units so multiplied by 1000 in solver variable within Electric powertrain.
Note: You can refer help document and library/example models to verify the unit system followed in FMU control and within motionview model.
3] Observed rear monoshock suspension motion ratio, stiffness and preload value issues. I have moved back and up just to solve the model with edited powertrain parameters. Please consider correct stiffness, preload values for the monospring spring based on required motion ratio.
Hi Jagadeesh,
Thanks for going through my model, I was stuck with this issue for a while now but thanks a lot for helping me out. I will definitely keep those points you mentioned in my mind. Earlier I had not correlated the powertrain with my suspension parameters, I left it at its default values.
Thanks
Draucis
hi Draucis,
Browse the the FMU file from the installation: ( \hwdesktop\hw\mdl\mdllib\Common\FMU_Library\Motor\FMU_source\FMUs\win64).
note: The fmu example file path can be seen when you assemble the library scooter or motorcycle. I suggest you to use 2022.2v so that FMU parameters can be edited (for custom values) easily within in motionview.
thanks,
jagadeesh
Hello Jagadeesh,
I tried your points for correcting the preload with reference to the motion ratio, spring stiffness. So, I took one of the examples in motionview as reference and my values for monoshock are based mostly on that. Still after tweaking the parameters you the model failed to solve, the model which you provided earlier, even that is failing to solve. I am out of ideas, is there anything else I might be missing out on.
This is the error the solver is giving:
X value out of range in AKISPL (spline id=-1)
Current x value 4555.71 > xend 4000, extrapolated y value : -6.49789
ERROR: Failure evaluating expression : "rtod*asin(VARVAL(30401300))"!
ASIN argument must be between -1 and +1!
And 30401300 is the id for a solver variable which is for Pitch.
Regards
Draucis
Hello Jagadeesh,
ASIN argument must be between -1 and +1!And 30401300 is the id for a solver variable which is for Pitch.
Regards
Draucis
hi Drucis,
Please share the latest model which is failing after update.
thanks,
jagadeesh
Hi draucis,
The model which I shared to you after correction belongs to 2022.1v which will not run in 2022v (version you are using) because of fmu inputs units difference. If you refer the help , fmu inputs and outputs are clearly mentioned in the table with units used. 2022.1v/2022.2v is recommended to use for electric powertrain as the powertrain inputs and outputs are standardised along with limited fmu parameters ( users to edit for new motor specs).
I have attached the mdl files, one belongs to 2022v and second model belongs to 2022.1v. between these versions fmu file from installation, fmu inputs and propulsion torque units are the only difference, please use these models and let me know if you face any new problems.
It is good to move forward with 2022.1v attached model running in 2022.1v/ 2022.2v MV . Also please refer 2022.1v/2022.2v library scooter model and help document for fmu file and units.
thanks,
jagadeesh
hi Draucis,
hi Draucis,
In my opinion the issue may be still with mass, cg and inertia values. When you deactivate the driver and run , the ground to frame planar joint is still active which helps to run default transient without any issue. Please refer MV example or library two wheeler model to compare the inertia values with your model.
In case the mass , CG, inertia entered values are good , then you can also look into (important) the "Lean PID" values available in the event editor "Driver" dialog page. The default Lean PID values in the event editor are need to be tuned as the mass and inertia of each vehicles will be different to control the direction and lean angleS. The lean PID related help can be seen at " ./hwdesktop/hwx/topics/motionview/tuning_controller_gains_to_improve_2wheeler_response_r.htm".
After all this, if you still see the problem,. you can share the model as Praful mentioned in the previous "custom inertia values" interaction so that we can study the model and help you.
thanks,
jagadeesh
