🎉Community Raffle - Win $25
Join and Win
Driver Resulting in Solver Failure
User: "draucis"
Altair Community Member
Updated by draucis
Hello,
Earlier I posted a question about the solver failing due to custom inertia values. Now that thing is sorted out, but the new thing is I am modeling with a detailed rider now, the solver is failing and sometimes not solving at all without error, so when I deactivate the driver, the solver works fine and when I activate it gives an error. I tried to simplify my model by adding a simple rider instead of the detailed one, but the error is still there. the error I get is the menitoned below. I have not edited the driver and have taken the default values for mass and inertia.
WARNING: Akima-interpolation -> Data out of bounds Spline id:0
         Future messages for Spline will be suppressed.
 Time=1.202E+00; Order=2; H=5.000E-04 [Max Phi=3.336E-07]
WARNING: [DASPK] The nonlinear system solver in the time integration could not converge
WARNING: EvaluateResidual failed (NaN encountered)! Future warnings will be suppressed.
         Residual idx=2214, GS/310001 X1
ERROR: [DASPK] IRES = -2 was encountered and control is being returned to the calling program
 DAE SOLVER STATISTICS (DASPK-Index3)
 Number of solution steps                 = 1341
 Number of residue evaluations            = 445
 Number of jacobian computations          = 516
 Number of error test failures            = 4
 Number of nonlinear convergence failures = 31
WARNING: Repeated abnormal return from integrator!
ERROR: At time=1.254E+00 the integrator failed to proceed.
after this there is list of probable causes.
Regards
Draucis
