piccolo launchpad
Submitted by veeraputhiran on Wed, 12/04/2013 - 17:28
Hii.... please help me to use the blocks for piccolo launch pad.. i just need to glow a single LED... thanks
Submitted by veeraputhiran on Thu, 12/05/2013 - 08:57.
i saw all the examples... i want to know the minimum blocks to access a single GPIO... please need support..
Submitted by Anders89 on Thu, 12/05/2013 - 10:01.
To blink an LED you need two blocks: a square wave block to create the on-off signal and a GPIO write block.
Square wave block is under Blocks > Signal Producer > squareWave, GPIO write block is under Embedded > Piccolo > Digital/Analog output for F280x.
Sample diagram is attached. You must sign in to see it.
Submitted by veeraputhiran on Mon, 12/09/2013 - 06:48.
thank you so much sir
Submitted by Anders89 on Thu, 12/05/2013 - 01:20.
We have a wide variety of Launchpad examples under the VisSim menu: Embedded > Examples > Piccolo > Launchpad. The diagram blinkLaunchpad28027 will blink all 4 LEDs in a binary count sequence.
