clean model from orphaned nodes
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hi,
i have some nodes in my model which are not connected to any structure or system or anything (=orphaned). I need to clean my model from them, how can i do this?
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited August 2015
    Hi,
    Goto Temperory nodes panel and click clear all.
    Shift+F2 is the shortcut to Temp nodes panel.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited August 2015
    Hi,
    that only works for temporary nodes marked with a yellow sphere. After clicking clear all on temp nodes panel, i still can find the orphaned nodes. I am using HW Desktop 13.0.112
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited August 2015
    Hi Florian,
    Check in which component collector they are. Isolate that component and it should be gone.
    if the above did not work, add the below Environment variables and values.
    Variable name: HM_DISABLE_MULTISAMPLE
    Variable value: 1
    Variable name: HM_LEGACY_NODE_DRAWING
    Variable value: 1
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-00708700-1440145517_thumb.jp
  • AlessioMM
    AlessioMM Altair Community Member
    edited November 2016
    Hi all!
    Sorry to update the thread but i have the same problem of florian_lw.
    I am not able to delete these orphane nodes in hypermesh. Where can i set the variable values, as explained by Prakash Pagadala?
    Thanks for the help.
  • evsm1982
    evsm1982 Altair Community Member
    Hello,
    You have to add all nodes as temp nodes (all nodes will be yellow) and after you have to clear all.
    in this way, all orphaned will be deleted.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi AlessioMM
    If you are using Windows OS, RIght Click on MyPC/MyComputer>> Properties>> Advanced System Settings>>Environment Variables>> Create new
Welcome!
Welcome!
