Altair RISE
Nominate Yourself Now!
Deformation
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Good morning
I did contact analysis between a cylinder and a plane. The result is below. Note in the image the wrong strain. My questions is how can I improve this?
Thanks in advance for assistance.
<?xml version="1.0" encoding="UTF-8"?>deformazione.PNG<?xml version="1.0" encoding="UTF-8"?>cilindro.PNG
1 - 11 of 111
    Altair Employee
    OP
    Hi Antonio,
    Is it plot of plastic strain?
    Where are you applying the loads?
    From the plot I presume you are apply the loads in the top of the semi elliptical block, is that correct?
    Altair Employee
    OP
    Hi Antonio,
    Hi Prakash Pagadala,
    this is the model.
    This is the analysis. I want to do an analysis of plastic deformation.
    Can you help me?
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    You are checking Displacement plot.In result type change Mag to Z axis and check displacement.
    Default Optistruct would not give strain as output.
    In control card request for STRAIN.Then only you would get strain as output.See attached screenshot.
    Altair Employee
    OP
    where can I find control card?
    Altair Employee
    OP
    Create your 'Load step' and then Card edit. There're OUTPUT options.
    Altair Employee
    OP
    Thank you very much. I did as you said but the wrong deformation remains. I am attaching the wrong strain.
    <?xml version="1.0" encoding="UTF-8"?>modello9.1.1.PNG<?xml version="1.0" encoding="UTF-8"?>modello9.1.PNG<?xml version="1.0" encoding="UTF-8"?>modello9.1.1.1.PNG
    Altair Employee
    OP
    These are hyper view images using the tool mask.
    <?xml version="1.0" encoding="UTF-8"?>modello9.2.PNG<?xml version="1.0" encoding="UTF-8"?>modello9.2.1.PNG
    Could you set Result type to strain and plot results?You have shared displacement plot.
    Altair Employee
    OP
    This is the plot of strain.<?xml version="1.0" encoding="UTF-8"?>modello9.2.2.PNG
    Altair Employee
    OP
    Good morning
    My problem is wrong deformation of two solids. you look at the image. near the arrow can be seen overlapping cylinder mesh with meshes of the plan. probably the program does not see well the area of the contact to me determined. can you help me?
    Thanks in advance for assistance and disturb.
