Altair RISE
Nominate Yourself Now!
how to use tcl script in hypermesh?
User: "shubham Dhokare_21832"
Altair Community Member
Updated by shubham Dhokare_21832
Does anyone know about how to use tcl script in hypermesh? for example tcl script to organize geometries in their respective components..
I receive 90 geometry files and only 15 to 16 are needed from them. So by making new component and moving the solid in that respected component it takes lot time and patience. I have tried by calculating mass of each solids and according to it tried to organize. But the solids that I receiving from my client changes (like small feature change) every time. So is their any other criteria I can use to oraganize this geometries .... if any please guide...
thanks
Shubham Dhokare
1 - 7 of 71
    User: "Nagahashi Kouta"
    Updated by Nagahashi Kouta
    Hi, shubham Dhokare
    If there are only small feature change for each new solid,the length&width&height of the new solid will match the old one(not only length&width&height ,the x_min y_min z_min x_max y_max z_max will be the same).
    Try to use "hm_getboundingbox" to get the information。
    OP
    Thanks Nagahashi, So if I create a bounding box for solid then how is that solid going to move in respected component.
    Hi, shubham Dhokare
    Sorry, can you provide more information? I don't particularly understand.
    If the old solid and the new solid have the same span in the XYZ direction, we think the two solids match.
    Use the following command to get the component name of the old soild.
    "hm_getvalue solids id=old_solid_id dataname=collector.name"
    Use the following command to move the new solid to the collector below.
    *createmark solids 1 "new_solid_id"
    *movemark solids 1 "component_name"
    OP
    Thank You Nagahashi I am new in hypermesh software and I didn't know how to create tcl script. I need a guidance to create this script. And actually I don't have any basic idea of script also. So if it possible to share any guide or anything so that I can follow it and learn it... That will be lot helpful for me
    Hi, shubham Dhokare
    Sorry, I followed Altair's official tutorials and learned how to write scripts.
    Maybe you could google the official tutorials.
    OP
    Thanks for the reply, Can you please share link of the tutorials ... Cause I try to find but didn't got it
    Accepted Answer
    Hi, shubham Dhokare
    Sorry, I can't access Google for some reasons, so I can't help you.
    You can try contacting your local office of Altair to get the tutorials.
