Hi, I am very curious that what type of description is used in HyperXtrude. If Lagrangian description is used, what's the solution for the extreme mesh distortion and deformation during the extrusion, especially in extrusion with flat die? Thanks a lot.
Hi,
HyperXtrude uses the Eulerian description. The mesh will not be distorted in this approach (stationary mesh and results 'move across the mesh'.
Best Regards
Jan
