ESLM
Dear all,
I am currently working on a cylinder head optimization using Optistruct.
The camshaft induces dynamic loads on the head. I would like to use the ESL method to convert these dynamic loads into static loads, but I can't find any help, or any tutorial on how to do that.
Is it while setting the different forces on the head, or do I have to run another analysis?...
Do you have any clue?
Thanks a lot
Best regards
Florian
Hi @Florian Kimmerlin
Did you get a chance to look at the example OS-E: 4015 Optimization of MBD System Level Response?
