🎉Community Raffle - Win $25
Join and Win
How to use "Custom" Mesh size in Lua with CADFEKO
User: "Sasha1296"
Altair Community Member
Updated by Sasha1296
Hello
I've been having a difficulty with meshing cubes, when I  run the command in lua script:
project.Mesher.Settings.MeshSizeOption = cf.Enums.MeshSizeOptionEnum.Fine
The mesh that is generated doesn't have enough triangles, I tried to fix this by writing:
project.Mesher.Settings.MeshSizeOption = cf.Enums.MeshSizeOptionEnum.Custom
project.Mesher.Settings.TriangleEdgeLength = 0.2
but I get an error: 'Empty expression is not allowed for Edge size.
Error 16628: Error in expression at position 0 for expression: Edge size = '
How can I fix this error and set the triangle edge length to 0.2 using Lua?
1 - 2 of 21
    User: "Mel"
    Altair Employee
    Updated by Mel
    Have you tried to script record setting a custom mesh size and then using script play back?
    In Feko 2020 if I do this I get:
    -- Updating mesh parameters
    MeshSettings = project.Mesher.Settings
    properties = MeshSettings:GetProperties()
    properties.MeshSizeOption = cf.Enums.MeshSizeOptionEnum.Custom
    properties.TriangleEdgeLength = '0.1'
    MeshSettings:SetProperties(properties)
    -- Mesh the model
    project.Mesher:Mesh()
    User: "Sasha1296"
    OP
    Thank you so much It worked!
