🎉Community Raffle - Win $25
Join and Win
Get the max and min value of Aspect Ratio for a element set with TCL
User: "Hideyoshi Santos"
Altair Community Member
Updated by Hideyoshi Santos
Hello everyone.
I'm checking the aspect ratio for a 2D mesh and trying to get the min and max values inside the set of elements selected.
This values ​​are made to be display in a tk_messageBox so is necessary to obtain this values ​​through TCL commands in the console/script.
Right now I'm only using the *elementtestaspect  witch give the elements that match the criteria in a mark and those that do not in another mark. With these I can only display the % of failure.
These is my code:
*createmark elements 1 "displayed"
*createmark elements 2
*elementtestaspect elements 1 20 2 2 0 " 2D Aspect Ratio"
set elements_OK [hm_marklength elements 1]
set elements_failed [hm_marklength elements 2]
tk_messageBox  -type ok -message "$elements_failed of $elements_OK  failed \n"
Hope you guys can help me.
Greetings!
1 - 2 of 21
