🎉Community Raffle - Win $25
Join and Win
ERROR ID : 760
User: "Arthur F"
New Altair Community Member
Updated by Arthur F
Hello everyone,
I face this error for several days now and I can't find where it comes from. I’ve checked on this forum and found multiple articles related to this error, but it doesn’t work for my case.
I’ve tried to change the gapmin in type7 interaction, even try to delete it but it doesn’t work.
I’ve checked each component; everyone has a property and a material.
I’ve tried to run the Check model tool to find the error, but there is nothing.
Since the last test of my model, I’ve only added a new fence with a honeycomb material. It seems like it’s working fine if I remove the fence property (SOL_ORTH). As I’m new with FE analysis and Radioss, It’s hard to find information and the error.
Here is the .out
Thank you for your help
 PS : I can't find the 'empty surface' from the warning in the .out file
