Altair RISE
Nominate Yourself Now!
1D beam dimensions are not updating in DOE.
User: "Venkatesh K"
Altair Community Member
Updated by Venkatesh K
Hi,
I'm working on Hyperstudy and i parameterized 1d beam Dimensions a, b (Hight, width).
I'm facing issue in DOE.
In DOE beam dimensions are not updating in main files (.fem) jobs  and its showing as generic in while reviewing.
Thanks.
1 - 4 of 41
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    what solver are you using?
    Are you working with a parametrized file? (.tpl)
    if it is OptiStruct, you could use PBARL/PBEAML to make it easy to parametrize your 1D model.
    User: "Venkatesh K"
    OP
    Hi Adriano A Koga,
    Iam using optistruct solver 19.1 version,
    I parametrized the beam dimensions a, b(width, hight) in Hyperstudy .tpl
    i used PBAR to parametrize 1D model.
    Thanks.
    Regards,
    Venkatesh k.
    Altair Employee
    Hi Adriano A Koga,
    Thanks.
    Regards,
    Venkatesh k.
    in the PBAR you would actually need to parametrize the AREA and Inertia Moments of the PBAR section.
    I'd change it to PBARL (if it is a rectangular section), where you enter directly the values of a and b.
    https://help.altair.com/hwsolvers/os/topics/solvers/os/pbarl_bulk_r.htm?zoom_highlight=pbarl
    User: "Venkatesh K"
    OP
    Hi,
    Thanks for the suggestion.
    I modified and submitted the job.
    Now iam facing some syntax error issue in model.
    Below i mentioned error details, please help me out.
    Thanks.
    *** See next message about line 911708 from file:
         Sol103_fullmodel.fem
      "PBARL   70008286       1                                        +"
     *** ERROR # 1479 *** in the input data:
     Incorrectly formatted numeric data in field 9.
     (If it is a character field, it should start with a letter.)
      Syntax error(s) in the current line:
     911708:PBARL, 70008286, 1, , , , , , >ERROR<
