🎉Community Raffle - Win $25
Join and Win
Connection between shell components
User: "Rahul_P1"
Altair Employee
Updated by Rahul_P1
Hello together,
I probably have just a simple problem.
I have 3 different components (PCOMP). Now I want to connect the yellow with the blue on and the blue one with the pink one?
How do I manage that?
Thanks for your help!
1 - 4 of 41
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Student_1739
    From the image it looks like the yellow component has elements of a larger size than the blue and pink ones.
    There also appear green connectors in the blue component.
    Do you just need a mesh transition from the yellow to the blue component? why are the element sizes so different between the components?
    Are you using connectors? if so which type and what is the purpose of these connections?
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    he mesh size of the yellow one is bigger indeed because this component is quite huge.
    it's true they are connectors but i was just trying to understad that function. so this is just to be ignored.
    I Need to build model with Areas of different properties. so I created 3 surfaces. Each as an own component.
    After started a dynamic Simulation but there is no interaction between those components.
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    I quick edit--> toggle edges function to create connected lines between concerning components.
    then I wanted to check the equvalence between the meshes. surprisingly there were none.
    now simulation is running. let you know if it worked...
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    it worked.
    just adding shared edges solved the Problem.
    thank you!
