🎉Community Raffle - Win $25
Join and Win
How change the Element Type and Order in Hypermesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
31 - 60 of 642
    Altair Employee
    OP
    how can I know if the SOLIDs are in Correct order or not?!
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Maybe try menu Tools>Model Checker
    Altair Employee
    OP
    No no, update 'Property' for your Meshing component !
    the components have No Property, still I have to create a new Property and update it?!!
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Yes please update the component with the appropriate property.
    Thankyou
    Altair Employee
    OP
    thanks for your answer.
    can you please tell which one is the apropiate Property,
    for example if the Element Type is SOLID 45 (Tetra4 for 1.Ordet Elements), the Appropriate Proprty is solid45p ?!
    and after that I have to export the Model and Run the Analysis in ANSYS ?
    thanks alot
    Yes. Please refer to help for more information also.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.290c35e4dd3790a55cda81894b77a7dc.png
    Altair Employee
    OP
    thanks,
    at your Screenshot i see that the ansys type of tetra10 is SOLID95 (because the Property was SOLID45p) you think that I have to change the Element type my model from Tetra10(2.Order Elements) wich are SOLID187 to SOLID95 and after that change the Order from SOLID95 to SOLID 45 ?
    thanks for your helping
    Can you please try to convert the Tetra 10 elements to tetra 4. then convert the tetra 4 to SOLID45p.
    Thankyou
    Altair Employee
    OP
    My Model is a very Big and have 187 Components, I have to change the Order only in few Components,not all of them.
    as I learned from you , to change the Order I have to Right Click on Component and then Edit it(Edit Card and select SOLID 45 and SOLID45p For Property,)then export the Model, and Run in ANSYS.
    For this Issue I Create a new Component and move that parts of model , which have to be changed to 1. Order in this new Component, and as I wrote up Right Click on this new Component and...
    My Question is that, for this new Component tha I Create by myself, which MAT I have to determine? (each of the Components,that are inside of this new Component have seprate MAT and Property)
    Thanks for your helping me
    IF this is the issue then place the model parts with different MAT and PROP under different Components.
    Altair Employee
    OP
    can you please a littbe bit explain?
    am I right understand? : I Put all this Components(For exmple 6 Components that I Selected from my Model) and define new MAT and new PROP for this new Component?
    If the 6 Components (parts of your assembly) that you mention have same MAT and PROPERTIES then you can put all of them under one component but if they dont have same MAT and PROPERTIES you have to arrange them under separate COMPONENTS in HM and then assign them the appropriate MAT and PROPERTIES.
    Thankyou
    Altair Employee
    OP
    thanks,
    The Problem ist exactly what you say,
    I think because the MAT and PROP of the Components are diffrent, I have to create for each Component separate new Component, and then chage the Order.
    But the Problem is : from 187 Component, I have to change the Order of  181 Components from 2.order to 1.order ( Tetra 10 (SOLID 187) to Tetra4(SOLID45) ).
    I have to create 181 new Component?!!! there is no other solution?
    If there is some other way i will ask some experts and get back to you as soon as i can.
    Thankyou
    Altair Employee
    OP
    thanks a lot
    Altair Employee
    OP
    I changed the Order and for each 181 Component :
    *Right Click/Edit Card/ select ET-Type (Wich is SOLID45)
    *Right Click on Component/Edit/Propery/ Select the new Property(Wich is SOLID45p)
    *Export the Model
    want to open it in Hypermesh, bit it can't open, and write this Error:
    then it remain only one way: Create 181 new Component with MAT and PROP, and move each of these Components in this New self created Components !!! after that do the same Process that I wrote up.
    BUT its really not Reasonable.
    Hope You have some good news to me.
    thanks for rour helping.
    Altair Employee
    OP
    This Model has 102 Property all of them are TARGET 170P
    when I create new Component and as you told want to define the Property  SOLID45P, I get the warrning about the Mix Property.should I define the Prppery again TARGET 170P and change the order (tO 1. Order, Tetra4) and export the model?
    Hello,
    Please follow the following procedure:
    1. You are in OptiStruct profile. Change the 2nd Order Elements to 1st Order elements using
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.0c5e1e122096900a08aa22ac7e669382.png
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.f494d6aaa9a894d9e9287b8df33c6941.png
    2. Now you have 1st Order elements.
    3. Now go to Tools>>Convert>>OptiStruct>>To Ansys
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.f3596a6608e5c246fd1e52d2e56fba9b.png
    4. Click on Convert
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.baf42b0dd33038432155dcaf639e0a4c.png
    This will convert the element type.
    Please refer the attached video for further assistance.
    Thankyou
    Altair Employee
    OP
    thanks a lot, I do it now
    Altair Employee
    OP
    I dont have in Tools/Convert/OptiStruct
    maybe because of the old version of my Hypermesh.
    then which Option I have to choose?
    Please click as shown in image
    Radioss Bulk data format is nothing but OptiStruct
    Altair Employee
    OP
    unfortunately it doesn't work again !!!
    What are you doing exactly after converting to Ansys?
    Altair Employee
    OP
    I want to open it again I Hypermesh
    when you are opening in HyperMesh again please check that before you open your model, your user profile should be set to Ansys.
    Altair Employee
    OP
    i did it
    but this Error appears and dont allow to open the Model.
    Please share the model.
    Thankyou
    Altair Employee
    OP
    Sorry I am Not allow to do it, I really be appriciat if you give me your tipps from hier.thanks a lot
    Hello,
    I tried the process in my machine on a sample model and the export as well as import is working fine for me.
    I would suggest you to upgrade your HyperMesh as I saw you were using 11.0
    Thankyou
    Altair Employee
    OP
    thank you.
    it could be the Version Issue, But I have to do it in this Version and can't update it.
31 - 60 of 642
